Our Maytag Model MTB1956DE is running, but neither the lights nor the display panel for the cooling settings are working (already checked the bulbs). The fridge part also seems warmer than usual. About a year ago we did replace the thermostat, but at that time the lights did work.
Problem fixed, turned out to be a sticky button which just was not connecting:o That was easy!
