Originally Posted by: locktech  yes I checked them several times. I am a ex dealer tech turned locksmith. I used my fluke meter and am very experienced using it. You are welcome. Sounds like the valve/regulator is the culprit. - The gas valve/regulator Part number: AP3866825
Good luck. Gene.
Originally Posted by: telephoneman  Thank you:) You are welcome. I'm glad you were able to fix it. Thank you for the feed back. Gene.
