I have an issue with the icemaker overflowing with water during the filling cycle of making ice. I am suspecting that the water input valve is the cause of the problem, am I correct?
When I verify the part number for the watervalve on the parts list, there are two identified, part number AP2071735 and part number AP2071736. Which one would be for the icemaker water supply or should both be replaced?
There is also another part number AP2071738, does this part replace both parts AP2071735 and AP2071736?
Having the same problem Bob... Might want to watch THIS thread...
