PoppaDick
#1 Posted : Tuesday, June 10, 2008 7:00:33 PM(UTC)
PoppaDick
Our Whirlpool 7 cycle/2 speed washer has started leaving clothes wet although it runs through the spin/rinse/drain cycle seemingly fine...except the rinse water keeps rinsing until the spin has stopped, then shuts off.
SublimeMasterJW
#2 Posted : Wednesday, June 11, 2008 4:55:10 AM(UTC)
SublimeMasterJW
Check to see if anything is in the pump. If the water sprays continuously till the end of the cycle then naturally the clothes will be wet. It may be that the timer is messed up Does it do it in all cycles?
PoppaDick
#3 Posted : Wednesday, June 11, 2008 6:03:06 PM(UTC)
PoppaDick
Yes, it is the same in all cycles. Timer was my first guess. I'll have to figure out where the pump is, huh? Thanks.
SublimeMasterJW
#4 Posted : Wednesday, June 11, 2008 8:03:04 PM(UTC)
SublimeMasterJW
remove the cabinet by flipping up the control panel and umplugging this lid switch connection right here:newswitch.jpgPOP them purty brass S clips with a long flat blade and remove the cabinet. The pump and other innards of interest will be revealed.
SublimeMasterJW attached the following image(s):
SublimeMasterJW
#5 Posted : Wednesday, June 11, 2008 8:07:11 PM(UTC)
SublimeMasterJW
lokky here at this breakdown of a whirlpool direct drive washing machine like yours:wires copy.jpg
SublimeMasterJW
#6 Posted : Wednesday, June 11, 2008 8:09:10 PM(UTC)
SublimeMasterJW
It just clips onto the motor(number 22 is the pump):power.jpg
Guest (4)
