AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Gas Dryer heats up for 2-3 min and then stops heating
When we start the dryer the burner lights up and heats just fine, but after a couple of minute it stops heating and never start heating again. Help?
Originally Posted by: Todd Spaeth  When we start the dryer the burner lights up and heats just fine, but after a couple of minute it stops heating and never start heating again. Help? You have to coils on the gas valve. The secondary coil is bad. So it will start the first time, and then when it cycles off and try's to come back on the ignitor glows, and now gas, then the ignitor shuts off. Replace the coils. It is a quick, cheap, and easy repair. Tom ApplianceEducator.com - Parts
Originally Posted by: kayakcrzy  You have to coils on the gas valve. The secondary coil is bad. So it will start the first time, and then when it cycles off and try's to come back on the ignitor glows, and now gas, then the ignitor shuts off. Replace the coils. It is a quick, cheap, and easy repair. Tom ApplianceEducator.com - Parts -Okay please let me know how to get to those valve coils? I have the same problem but I could not see those valve coils. Model: LGR5620KQ1 Whirlpool gas dryer
Dryer Repair
