Pocketchange
#1 Posted : Monday, July 12, 2010 1:25:06 PM(UTC)
Pocketchange
The washer arm on the dishwasher will not move. I can hear what sounds like a small motor that just hums, when in the washing cycle.. I have tried to locate anything inside the washer tub that I can move to try and free it, but there is nothing, the only moving part i can see is a plastic propellar type part, which did nothing.
The water is being pumped into the machine but it seems that there is not enough pressure or force to get the waher arm to move... What do I look for ??
#2 Posted : Monday, July 12, 2010 4:36:07 PM(UTC)
Remove the bottom panel and check if the wash pump motor is working during the wash cycle.
Here are the breakdown diagrams and Motor & pump replacement parts for FRIGIDAIRE FDB126RBQ2 Frigidaire/dishwasher | AppliancePartsPros.com
#3 Posted : Wednesday, July 14, 2010 10:43:51 AM(UTC)
Would like to suggest, you start your own thread in the Washer Repair section, using Post New Topic. Do not forget to post the complete model number of the washer.
People will then see it is someone with a problem.
This should increase your odds of getting a relevant reply.
