diy_guy33
#1 Posted : 15 years ago
diy_guy33
Hello, My fridge stopped working today. Forgiv me but I'm new at the electrical testing side of things. At first the freezer was working ok and the fridge was not. After pulling out to clean the condensor and unplugging then replugging in both are not. Below are pictures of the board, the 2nd shot is a closeup of the bottom right of the board. I Thoughts on where to check or does prelim sound like board? Any help greatlu apprecaited. Rick
diy_guy33 attached the following image(s):
diy_guy33
#2 Posted : 15 years ago
diy_guy33
Update: not sure why it didn't post this but, I tested j11 and j9 ok at 120v, j8 had nothing.
#3 Posted : 15 years ago
Pull your motherboard out and check the solder connections near the big power relay, just might be bad.
Did you locate your schematic, might be behind the control panel?
