I have a Bosch SHU5306UC12 dishwasher and it is stuck on 1 minute. I have read several blogs on this site with similar problem most being a control panel, however I have the control panel out and there are no burned solder points and it has the 10 amp relay. When I run the self test it gets to the heating and circulating test and never comes off of it to go to the draining test. I have to manually skip this test. The fault code comes up as a Zero which in the chart shows a bad flow switch. I replaced the flow switch today though it was only off by one ohm and still have the same problem. The heater, flow switch, hi limit and NTC ohms all test good and as listed. Is it possible the heater relay is bad on the control panel still though it is not burned? Any help would be appreciated. PS If I open the dishwasher while stuck on the 1 minute the water it hot, sudsy and is circulating. When I drain it by using the cancel mode it drains as it should so I know we do not have a plugged drain. I would appreciate any expertise you could give me.. Thanks
Did you ever solve this problem. I have same problem with Bosch SHU6805 - stuck on 1 minute - water very hot - drains when I manually cancel cycle. FYI - we generally don't have hot water so washer heats water (from 75F) most of the time. Thanks in advance for your help!
I replaced the control panel and it fixed the problem. Still working today.
