KCgallimore
#1 Posted : Tuesday, July 6, 2010 12:24:10 PM(UTC)
KCgallimore
Hello everyone... I am pretty new to this site, and have looked over it a good deal. There seems to be a lot of knowledgable people who help and visit here. So I am turning to you guys hopefully to help me look in the right direction.
Problem: Dryer will not turn on at all.
I can not hear any hum noise when pushing or holding in the start button, and it just seems dead.
Doesnt seem to be jammed. I turned the drum. It was very tight though. Dont remember it always being that tight to turn.
I have checked brakers.
Checked it with an ohm meter, and that turned up nothing.
I have turned it with the clip inside the door pushed in, and the start button pushed in. It didnt start up then either.
I do not see anything in the back to give away any kind of issues either. No burning sighted or anything like that.
If any of you can help that would be great.
Thank you
Cass
#2 Posted : Tuesday, July 6, 2010 5:33:29 PM(UTC)
Cass,
Remove the rear panel and check the thermal fuse (#19 on the diagram) for continuity. If there is no continuity, replace it.
- The thermal fuse Part number: AP3132867
KCgallimore
#3 Posted : Saturday, July 10, 2010 5:20:43 AM(UTC)
KCgallimore
Thanks for the reply Gene. We tested that fuse today, and that does not seem to be the issue. We will keep trying.
Cass
Brevard Appliance Repair
#4 Posted : Saturday, July 10, 2010 12:48:38 PM(UTC)
Groups: Expert
I would guess the thermel fuse as well but since you tested it and its good then check your door switch...good luck
#5 Posted : Saturday, July 10, 2010 6:55:30 PM(UTC)
Here is your wiring diagram in case you do not have it
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdf
Also check the start switch.
First I would check the power
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
