Dave1973
#1 Posted : Friday, July 9, 2010 11:29:32 AM(UTC)
Dave1973
Recently my ice maker bagan leaving a trail of water all the way down the door which in turn became a glacier. Also the ice holding tray was getting water in it whcich would freeze the cubes together that were already in it. I read several sites and found that the tube coming in from the back had a small piece of ice on the tip and that supposedly could mean the valve on the back was leaking a bit so I came here to find the valve AP3706447 (WR57X10050) which I bought here and replaced. I am not sure if I was shipped the wrong one or if it is bad or if I installed it wrong (it will only fit one way and is hooked up correctly) but it doesnt do anything now. No ice in tray or on door LOL. Did I replace wrong part and nothing was wrong with old one and now whatever was bad is now completely out? Any ideas of what to check other than just throwing parts at it would be much apprectiated.
#2 Posted : Friday, July 9, 2010 5:35:47 PM(UTC)
What is the status of the green LED light on the right side of the ice maker?
Here are the breakdown diagrams and Replacement parts for General Electric A4425GDTAWW Refrigerator | AppliancePartsPros.com
Dave1973
#3 Posted : Friday, July 9, 2010 6:18:04 PM(UTC)
Dave1973
The light is on and it is on the left.
#4 Posted : Friday, July 9, 2010 6:27:47 PM(UTC)
Is it blinking?
Dave1973
#5 Posted : Saturday, July 10, 2010 9:29:07 AM(UTC)
Dave1973
No sir. It stays on all the time.
#6 Posted : Monday, July 12, 2010 1:15:24 PM(UTC)
Dave,
Quote:
...No ice in tray or on door...
I missed it in your very first post. Have you checked the incoming water line after you replaced the water inlet valve?
Dave1973
#7 Posted : Monday, July 12, 2010 1:42:37 PM(UTC)
Dave1973
I have done nothing other than verify that I connected it LOL. In case the valve I bought herre might be bad I was thinking today of putting the old one back on to see if it goes back to making ice everywhere. If I need to check the line in another way please let me know. Years ago I worked on washers and dryers. Obviously this is neither!
#8 Posted : Monday, July 12, 2010 2:01:05 PM(UTC)
Dave,
You had to disconnect the incoming water line in order to replace the water inlet valve and you had to shut off the water to the refrigerator at that time. Did you open it after you finished the repair?
What kind of shut off valve do you have for the refrigerator? If this is a self piercing saddle valve, then the problem can be a clogged pierced hole in a copper tube.
Dave1973
#9 Posted : Tuesday, July 13, 2010 5:36:35 AM(UTC)
Dave1973
I have checked and water flows freely to the valve.
#10 Posted : Tuesday, July 13, 2010 3:11:45 PM(UTC)
Remove the wires from the dispenser solenoid on the water inlet valve. You can find it by a 5/16" tube connected to it. Check for 120 VAC between these wires while the dispenser calls for water.
Guest (4)
Cafe induction range issue... Help please! (Oven Repair (including Ranges and Cooktops))
by Guest 1/29/2023 7:31:31 PM(UTC)
replaced faulty heating element, now dryer gets too hot. Help please! (Dryer Repair)
Belarus sheriowaso 11/15/2013 4:21:37 PM(UTC)
Help Please!!! (Refrigerator & Freezer Repair)
by kgmccurry30 1/25/2013 1:14:49 PM(UTC)
Defrost system isnt work. Help please! (Refrigerator & Freezer Repair)
by dannycip72 11/13/2012 5:17:18 AM(UTC)
Help Please! My Hotpoint is baffling me (Dryer Repair)
by monsieurt 9/18/2012 5:25:41 PM(UTC)
Help Please! LG Water in door not working (Refrigerator & Freezer Repair)
by Rodney01 12/3/2011 4:45:28 PM(UTC)
Amana - Distinction - No longer cold!! help please!! (Refrigerator & Freezer Repair)
by drewx24 8/18/2011 10:35:37 PM(UTC)
Help Please!! (Washer Repair)
by ncrow02 8/18/2011 11:29:30 AM(UTC)
Help Please! (Dryer Repair)
by Graphic Designer 2/17/2011 12:20:30 PM(UTC)
HELP PLEASE!!! Frigidaire Washer will agitate and drain, but not spin (Washer Repair)
by jadten 11/29/2010 9:41:46 AM(UTC)
Microwave help PLEASE!!! (Microwave Repair)
by nneysari 10/19/2010 11:34:10 AM(UTC)
Help Please! Dryer on Runs when pust to start button is depressed (Dryer Repair)
by rcmajb 10/4/2010 3:42:58 PM(UTC)
by Alltime 4/21/2010 3:34:52 PM(UTC)
help PLEASE! (Washer Repair)
by skindig79 7/8/2009 11:08:12 AM(UTC)
Whirlpool Compressor Help Please!!! (Refrigerator & Freezer Repair)
by southernthunder 3/8/2009 7:25:55 PM(UTC)
