nancytp2000
#1 Posted : Friday, July 9, 2010 11:27:57 AM(UTC)
nancytp2000
I bought the part from you... came with no instructions. back is off fridge, how does valve get disconnected. WHAT GOOD IS A PART IF YOU DON'T SEND A SCHEMATIC OR INSTRUCTIONS WITH IT?
#2 Posted : Friday, July 9, 2010 4:20:46 PM(UTC)
Originally Posted by: nancytp2000 Go to Quoted Post
...WHAT GOOD IS A PART IF YOU DON'T SEND A SCHEMATIC OR INSTRUCTIONS WITH IT?...
All the installation instructions are made by the manufacturer and only the manufacturer decided to include or not such instructions with a part.
Shut off the water to the refrigerator. Disconnect the incoming water line from the water inlet valve. Remove the plastic tubes from the water inlet valve by pushing in the center collar while pulling out the tube.
Install the new water inlet valve in the reversed order.
Here are the breakdown diagrams and Replacement parts for MAYTAG MSD2351HEB Ref - SXS/I&W | AppliancePartsPros.com
nancytp2000
#3 Posted : Friday, July 9, 2010 4:54:01 PM(UTC)
nancytp2000
Thanks for your help, Gene.
The tubes are easy to remove, once you know the trick.
Nancy
#4 Posted : Friday, July 9, 2010 6:22:02 PM(UTC)
You are welcome Nancy. I'm glad you were able to fix it.
