I have a question regarding the installation of a defrost heater kit on a Frigidaire side by side, model FRS26H5ASB5. I removed the cover over the coils and found the wires for hook up but I am having trouble knowing where to route the heater as it was removed already.
Groups: Expert
The heater is mounted at the bottom of the evaporator, and is usually held in place with metal clips/brackets. However, due to the process needed to install that heater, which I believe is going to look like an "L", you have to pull the bottom of the evaporator away from the wall. I would HIGHLY RECOMMEND you dont try this yourself, because without proper training, you can damage part of the evaporator coil by bending it, in a way similar to kinking your garden hose, and if you do that, that is a MAJOR repair, and VERY expensive. I would seriously consider calling a local refrigerator repair company and have them install that for you.
