I have kitchenaid over the range microwave. Mircrowave works fine but looks like fan is not turning on with microwave. I noticed food get heated. Any help ?
Originally Posted by: Vivekbharti  ...looks like fan is not turning on with microwave... Which fan - exhaust fan or cooling fan? Gene.
Cooling fan. The fan which turn on with microwave.
Remove the cooling fan (#14 on the diagram). The disassembly instructions are in the Service manual.
Using an external 9 or 12 DC voltage source, connect to fan wires: red (R) wire to “+” and black (BK) wire to “-”. If it does not work, replace the fan. If it does work, replace the control board. - The cooling fan Part number: AP3177894
Gene Thanks. Got fan last week and installed it. Microwave is working now. Thanks again
