whiplash
#1 Posted : Monday, July 5, 2010 6:46:42 PM(UTC)
whiplash
I have a Maytag Wide by side, fridge side quit cooling, found out freezer was froze up. Tried crossing the two wires on the adaptive defrost board to start the defrost timer, but still don't defrost. Which one is it?
#2 Posted : Wednesday, July 7, 2010 5:22:59 AM(UTC)
Replacement parts for MZD2768GE models | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/maytag_library/docs/16010154.pdf
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
Unplug the unit.
Remove the evaporator coil cover.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms (on your unit it looks like it may be 240 Kohms) when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
