runs fine up until final rinse and spin starts good but slows and burning rubber smell comes from drum clothes are not fully rung out what is this problem is this a motor or a belt? or could the motor be loose and cause this malfunction and how do i find a online copy of my owners manual to view the motor compartment?
Could be your clutch slipping, take the front panel off, and look at the clutch for heat discoloration, here is the breakdown. Model WJSR2070B0CC
