Lights on touch control pad won't come on and dishwasher won't start. At first it was only the sanitize light that would not come on - now none of the lights on the control panel won't come on. :confused:
THIS FORUM IS DEAD!!!!!!! |
I have the same issue, How would I go about checking that both door switches are closing??
Check them with a meter to make sure they are closing. To see if they are mechanically closing just do that visually.
You could short the wires to them together, taping them up to be sure they do not short to something else and give it a try.
Be sure to tape/hold something over the units opening, unless you want a bath. Also have someone else at the ready to shut off power to the unit if it does start up. |
