sroloff
#1 Posted : Tuesday, July 6, 2010 9:33:33 AM(UTC)
sroloff
I just repaired my dryer putting in 3 new thermostats and some other things since flame was cutting out - that was about 3 weeks ago and since that repair everything had been working fine... until now. Now what is happening is that when dryer is cold the dryer works fine but once being used for a bit the glow stick glows but the gas doesn't ignite.
What now?
#2 Posted : Tuesday, July 6, 2010 12:34:25 PM(UTC)
Most likely the problem is a bad gas valve coils. If you need the correct part number for the coil kit, post the serial number of the dryer.
Here are the breakdown diagrams and Replacement parts for MAYTAG DG412 Dryer - Gas | AppliancePartsPros.com
sroloff
#3 Posted : Tuesday, July 6, 2010 5:54:33 PM(UTC)
sroloff
Serial #758539 TA
#4 Posted : Tuesday, July 6, 2010 6:15:31 PM(UTC)
The coil kit Part number: AP3094251
