My Tappan 12-1863-10/03 circa 1994 oven has stopped igniting, even though I have a bright orange electric ignition pilot. I cannot detect any gas flowing. I believe I have 2 items in the gas chain:
Regulator P/N RV47NCLS 1/2 PSIG
Igniter P/N (I have electricity to this part) 9405 NAT NC4148-5 774S014P02
Can you suggest a method to determine which is faulty and should be replaced?
Measure the current drawn by the igniter when it's on. If it's less than 3.2 amps - the igniter is bad and has to be replaced. - The part number for the oven igniter is AP2150412 Gene.
Originally Posted by: Gene Measure the current drawn by the igniter when it's on. If it's less than 3.2 amps - the igniter is bad and has to be replaced. - The part number for the oven igniter is AP2150412 Gene. Gene, I do not have the tools to measure AC current. I've disconnected the leads to the safety valve,P/N AP2139126 , and measured 1 ohm static resistance across its terminals; After turning the oven ON, I measured the AC voltage at the terminals (unloaded) at 114VAC. I turned the oven OFF, reconnected the leads and turned the oven ON, and again measured the voltage, now at 2VAC loaded, from 114VAC unloaded. Can I conclude that this igniter is the problem, or is the issue with the safety value? Sincerely, alr
Gene, The igniter was replaced, and the problem was solved. Thank you for your information alr
I'm glad you were able to fix it.
When turning on the oven, (digital panel) I smell gas and then the oven seems to ignite with a Poof sound thats strong.
Most likely the problem is a bad oven igniter. Also I would recommend to check the burner for burned through holes. - The part number for the oven igniter is AP2150412 - The part number for the bake burner is AP3220504 Gene.
