hawgswon
#1 Posted : Monday, July 5, 2010 3:12:50 PM(UTC)
hawgswon
I Have A 30 Year Old Whirlpool, Mark I Series Frig. IT Won't Shut Off. Keeps Running Until I Turn It Off. Can Someone Give Me A Clue As To What To Do. Hawgswon.
FridgeDoctor
#2 Posted : Monday, July 5, 2010 5:22:00 PM(UTC)
FridgeDoctor
Groups: Expert
Is food too cold? Refrigerators are designed to run until they are the proper temperature. They are not designed to run for a specific period of time. If its running too long and its too cold in the refrigerator section, then you have a thermostat issue not sensing correct temperatures.
If however, its not cold enough in the fridge, it could be a fan is not running, a door is not sealing well, a light is staying on, the fridge is in the hot garage, a weak compressor or leak of refrigerant or some other problem Id have to inspect to see.
