How do I remove the dial from the washer. the front of the dial just spins, however the back part works fine.
Push it in and it will unscrew
push the knob in or the dial?
Push in the knob and unscrew it, then you can remove the dial
Good luck
Dial removal
(Dryer Repair)
by Lmf101
2/20/2013 3:44:36 PM(UTC)
Timer dial removal
(Washer Repair)
by Tom C
8/12/2008 10:48:55 AM(UTC)
