georgenglish
#1 Posted : Thursday, June 5, 2008 11:22:38 AM(UTC)
georgenglish
Defrost timer stuck, replace defrost timer, would not stop running, manually turned timer compressor stopped running. put on a outlet timer to shut off evry two hours, then run for 30 min. Will this work, and will it cost more on energy. Thanks George
#2 Posted : Friday, June 6, 2008 1:40:03 AM(UTC)
Remove the freezer back panel and describe the frost pattern on the evaporator coils.
georgenglish
#3 Posted : Friday, June 6, 2008 8:08:13 AM(UTC)
georgenglish
There doesn't appear to be any frost ? Question, can I use a manual timer, how many times does a refrig. cylce in an hour, to keep minimum cool? Thanks, George
