cedsteph
#1 Posted : Thursday, July 1, 2010 9:08:26 PM(UTC)
cedsteph
Recently my washer started banging a bit during spin cycle. Last night it started banging very loudly. I ran into the laundry room and it was walking across the floor. After stopping the washer I started adjusting the load inside and noticed that the tub moves from side to side and doesn't reach the top. I'm guessing that I need to replace the front struts. How do I tell if they're bad? Do I need to replace the back struts also? They seem ok.
dh1200s
#2 Posted : Thursday, July 1, 2010 9:37:51 PM(UTC)
dh1200s
See if this post will get you started. Maytag Neptune load unbalance…..
Did your FAV6800A shut down with an unbalance error codes such ad dC or uC or did you stop the washer?
You will find a link to the Service Manual in the above post. Pull the front cover and you can look at the front struts and see if one or both are sagging. I haven’t seen a front strut fail to date but it could happen. The rear of the Outer Tub hangs off non hydraulic struts/hangers the front are piston struts.
See the machine cabinet parts view;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5169371&diagram_id=1327945#d1327945
Let me know if I can help. Right now I lean toward a Clutch Malfunction……Dick
SM link for quick reference; http://www.servicematters.com/m...ibrary/docs/16022808.pdf
cedsteph
#3 Posted : Friday, July 2, 2010 8:51:04 AM(UTC)
cedsteph
It has never displayed a code. I stopped it right away and did'nt use it after. We took the front off. I just don't know what the struts should look like if they are bad. Would they be collapsed? There is probably a couple of inches of the rod showing. The tub seems to have dropped below the splash guard about an inch or so. Oh, by the way thanks for responding, sorry I didn't start with that because I am very grateful for your help
dh1200s
#4 Posted : Friday, July 2, 2010 11:31:37 AM(UTC)
dh1200s
With the front cover off is the tub sitting level?
Is one front strut compressed more that the other?
I have a pic in the post I linked you to of a FAV6800A I was doing clutch maintenance on. It may be hard to tell but do you struts look similar to yours (resting position) with the front cover off? Or do you have one strut sagging more that the other?
If you press the left and right side of the tub down to compress the left and right struts do they compress equally and return to a level setting?
I have about an 1”gap from the Tub top to the washer top might be a little more but the washer guard splash over laps the gab by just enough.
I still lean toward a clutch issue. Do a spin only load and with a couple of damp bath towels and see if the machine will error out with an unbalance error dC or uC. If it doesn’t and it’s banging around a few seconds hit the Off Button.
Got to leave for work maybe I can take a pic tonight for better description.
Dick
dh1200s
#5 Posted : Saturday, July 3, 2010 8:46:59 AM(UTC)
dh1200s
“”I ran into the laundry room and it was walking across the floor.””
I should have asked you to check the Tub Displacement Sensor for proper operation.
From what you describe the machine should have shut down with an unbalance error code of dC or uC for such violent tub excursions. You may have two issues here.
I prefer to measure the TDS D.C. voltage swings to the Control Board but here is a thru the lid check process it’s in the Service Manual page 19.
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you fail this test it would be time to remove the machine front cover check if the TDS sensor has unseated from its mounting position between the Tub and the washer frame.
Here are some pics of the Splash Guard and Front Struts best I could do.
The Struts look like aI have around 2.5" of height from the piston rod to the top of the strut plate on the Outer Tub.
The last pic I show the TDS unseated for checks you don't need to do this.
Just make sure with the Front Cover off the TDS is lached properly to the Wash Tub and Washer Do the thru the lid check for range of motion check. If we need to get down to a more accurate measurement for proper range of motion check we will address.
Hope this helps….Dick
dh1200s attached the following image(s):
