Where can I get a replacement bake element for a Kenmore model 911.41489 built-in self-cleaning oven? It is probably manufactured by Whirlpool or GE. Sears does not offer a replacement part. I have not been able to find a part number to search other sources. Thanks for your help!
I looked up the 911 and it says Roper but parts available through GE. So you may want to call GE.
Also it may be worth emailing / calling AppliancePartsPros often even if a unit does not come up when searching they still can cross reference replacement parts. |
THIS FORUM IS DEAD!!!!!!! |
Thank you, denman. I found a GE part (WB44K10016) that looks like the one I need to replace, but how do I confirm that it is the right part?
I looked up the numer on AppliancePartsPros they sell it as AP3860687.
Perhaps they can confirm that it will fit your unit. |
