csbarnard
#1 Posted : Tuesday, June 3, 2008 3:26:39 PM(UTC)
csbarnard
HELP!!! My dishwasher will not drain or wash. I found a broken glass in the dishwasher and I believe a piece fell in the bottom but I can't see it. Can can I take the bottom apart to inspect and clear anything that in blocking it?
Thank you,
Cindy
csbarnard
#2 Posted : Wednesday, June 4, 2008 4:30:28 PM(UTC)
csbarnard
Please Help! How do I take apart the bottom to open it to fix. I've taken out the bottom rack and looked with a flash light and I dont see any screws to take apart.
#3 Posted : Thursday, June 5, 2008 4:31:22 PM(UTC)
Hi Cindy,
Unscrew the lower spray arm cap and remove the spray arm. Remove all screws (#3 on the pump break down diagram) and remove the pump outlet (#14 on the pump break down diagram).
Here are the break down diagrams for the Whirlpool dishwasher Model DU929PFGQ2
