nobake
#1 Posted : Wednesday, June 30, 2010 5:54:33 PM(UTC)
nobake
Hello, I Have A Jenn-air Range With Down Draft, My Problem Is That When I Turn On The Oven I Can't Raise The Temperature Above 350 Degrees. Also The Timer Function Will Not Work. The Broiler Will Also Come On But Again I Can't Raise The Temperature. The Exhaust Fan Will Work When The Broiler Comes On And Also When I Actuate It With The Toggle Switch On The Panel. Not Sure If It Is In The Soft Touch Button On The Panel Or If It Could Be Something Else Like A Thermostat Or Hi Limit Switch. I Really Like This Oven And Don't Want To Get Rid Of It. Any Help Would Be Appreciated.
