Trying to get some help with troubleshooting my washer. When I try to run it doesn’t stop when the cycle ends it just keeps continuously running. I replaced a timer on it, but it did not solve a problem. Also I noticed that water doesn’t drain while it runs a cycle and the only way to drain is to lay draining tube on the floor. I’m thinking maybe there is a problem with a pump and it causing washer to continuously run. Thanks for any help.
Anyone has any ideas what could be the problem.
