AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Kenmore Ultra Fabric Care Dryer (gas) won't spin
The dryer will make a low buzz when the starter button is pressed, but it does not spin. I was not there, but apparently the dryer was functioning normally, then all of a sudden got much louder. Upon inspection, the drum wasn't spinning, and the air and drum were hotter than normal.
I opened up the beast, shop-vacuumed the lint bunnies away, and examined the insides. The belt appears to be integral, with no splits or fraying. I can pull the belt one-handed to spin the drum, so it appears that the belt and rollers are at least functioning, albeit not functioning optimally after 15 years of laundry rolling through.
When the button is pushed, I do not feel nor see any attempt to move the belt, just a buzzing noise. Bearings in the motor could be shot, I suppose.
I would consider replacing parts such as the motor, belts, rollers, etc., but don't want to put a couple hundred into this dinosaur; would rather get a new one and hope to live long enough to take the energy savings into the black.
Anybody have any more advanced ways of checking the belts, rollers, etc., or is the fact that I can manually spin the drum with the belt sufficient to rule those parts out?
I'm taking the whole darn thing apart tonight; should be either the solution or a funeral service soon.
Originally Posted by: tdmbulk I'm taking the whole darn thing apart tonight; should be either the solution or a funeral service soon. Turns out a sock somehow managed to get into the motor housing and jam things up. Apparently at one point the dryer was run without the lint filter installed at all, and the sock eventually migrated into the motor area. After removal, the dryer is back to working, and is much cleaner to boot.
Just wanted to say thank you for sharing your diagnosis and repair with us. It is not often we see a sock in the motor housing, so your post was very illuminating and instructive.
Good luck with your dryer.
Dryer Repair
