This dryer won't heat up. I replaced the igniter with a known good one and checked the thermal fuse with an ohm meter . It shows continuity. The schematic is not legable. What can I check next ? :confused:
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
dryer does not heat, model #kgys677eq2
need help with my Ka gas dryer which does not heat
Originally Posted by: carl desordi  need help with my Ka gas dryer which does not heat model kgys677eq02
