cwiper
#1 Posted : Thursday, May 20, 2010 7:16:33 PM(UTC)
cwiper
Had the 2h problem. Could not find a burnt heater relay. Replaced control module and ran tests. Error code 2, heater problem. Where is it? How do I get to it? The whole underside of the washer is molded plastic.
cwiper
#2 Posted : Saturday, June 5, 2010 9:54:59 AM(UTC)
cwiper
This is to help others with a like problem. Nothing in the self test helps if the circulation pump rotor has become dislodged and melted inside its housing, which is what was wrong after I achieved complete disassembly of everything under the tub! A melted part does not speak well for the durability. Trail and error mostly on disassembly. Two screws front and rear and set on back and remove metal stays for door tensioner and the bottom slides away. Wiring needs to be managed but everything basicly falls apart for access. If you change parts beware that they do not give you any hose clamps, and the ones you take off are not reuseable. Small hose clamps are actually hard to find also. I had to go to a specialty fitting company to make it work. Good Luck
sigi502
#3 Posted : Monday, June 28, 2010 5:56:52 PM(UTC)
sigi502
Hi Cwiper,
the circulation pump on my DW is broken as well and I have the problem as well to remove the bottom to get access to the pump. I have a SHU 9920 model. I have already removed the obvious srewa on the front (under the kick panel), but don't know where the screws on the back would be located. Could you also explain, what you mean by 'metal stays' ?
thanks, Sigi
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Bosch dishwasher troubleshooting (Dishwasher Repair)
by Dan T in SD 12/7/2023 2:38:23 PM(UTC)
Bosch Dishwasher intermittently leaking on lower right of door (Dishwasher Repair)
by jjtrinva 11/5/2023 9:30:06 AM(UTC)
Bosch Dishwasher Model SHE3AR56UC/07 (Dishwasher Repair)
by EDK1747 8/30/2023 7:42:58 AM(UTC)
Bosch Dishwasher SHE3AR56UC/07 (Dishwasher Repair)
by Guest 8/27/2023 11:27:21 AM(UTC)
Bosch Dishwasher skips to "clean" even after part replacement (Dishwasher Repair)
by Guest 6/20/2023 5:17:19 PM(UTC)
Bosch dishwasher SHX65T55UC/07 not dispensing soap unless in "Express" mode (Dishwasher Repair)
by callussun 4/19/2023 9:46:00 PM(UTC)
Bosch dishwasher shem3ay 55n/25 (Dishwasher Repair)
by Guest 3/23/2023 5:18:20 AM(UTC)
Bosch dishwasher only drains on reset and specific cycle (Dishwasher Repair)
by vusedad 10/18/2022 8:54:46 AM(UTC)
Bosch dishwasher model SMV41D10EU/48 Not working (Dishwasher Repair)
by adriandlb 10/7/2022 12:18:47 AM(UTC)
Bosch Dishwasher SHX68T55UC/02 Leak Identified: How to Fix? (Dishwasher Repair)
by jonneytaee 8/31/2022 4:48:51 AM(UTC)
Bosch Dishwasher Model SHPM65Z56N (Dishwasher Repair)
by Guest 7/8/2022 9:00:03 AM(UTC)
