2 Pages12>
avismich
#1 Posted : Tuesday, June 3, 2008 7:34:04 AM(UTC)
avismich
Help! Is there a trick to getting the selector knob off of my ge washer?
It seems to be broken(or the timer knob skirt is broken)I'm not sure what part to order & how to get it off to see what the problem really is. ( It very easily spins without resistance.) It logically seems to me that this may be a commom problem:confused:
abadfish66
#2 Posted : Tuesday, June 3, 2008 7:46:37 AM(UTC)
abadfish66
Pull the knob out as if to start a cycle. Now look on the back side of the knob, and you will see a keeper that holds the knob onto the timer shaft. Get a small flat head screwdriver and push the keeper off, and you knob will come right off...here is the breakdown of the knob and timer.FYI.. the knob does spin freely, thats the way it's designed 1. section
avismich
#3 Posted : Tuesday, June 3, 2008 7:59:14 AM(UTC)
avismich
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
abadfish66
#4 Posted : Tuesday, June 3, 2008 8:09:47 AM(UTC)
abadfish66
Model WCSR2070T2WW
Go to section 2
avismich
#5 Posted : Tuesday, June 3, 2008 12:45:39 PM(UTC)
avismich
Hello Badfish 66 & thank you for that info. I did get the knob off, and then the keeper fell into the washer and I can't find it. It does not look like anything is broken. Could it be that the keeper just slipped out of place, or that the small protrusions that the knob fits into are stripped?
(the whole problem is that I have to hold & turn the timer shaft along with the knob to start a load of clothes.) Thanks again.
abadfish66
#6 Posted : Tuesday, June 3, 2008 12:53:43 PM(UTC)
abadfish66
Look at the back of the knob, there should be teeth on the part that goes into the timer, chances are those teeth are ground down, if there's no teeth you need a new knob. Order a new keeper as well.
avismich
#7 Posted : Tuesday, June 3, 2008 1:02:41 PM(UTC)
avismich
also I did not get that breakdown of the knob and timer. thanks:)
abadfish66
#8 Posted : Tuesday, June 3, 2008 1:05:51 PM(UTC)
abadfish66
Model WCSR2070T2WW
click this link
on the left side, select section 2, that is the breakdown
avismich
#9 Posted : Tuesday, June 3, 2008 1:06:44 PM(UTC)
avismich
Ok, I guess I need to order both parts. It looks that you need to take the whole top assembly apart to install them. Do you think I should call some one in to fix it?
abadfish66
#10 Posted : Tuesday, June 3, 2008 1:09:34 PM(UTC)
abadfish66
if your just replacing the knob and keeper, you don't have to remove anything. just put the keeper on the knob just enough so it stays on without it sliding down the groove, put the knob on the timer shaft, then push the keeper in place.
Guest (5)
2 Pages12>
