lmpiazza
#1 Posted : Wednesday, June 23, 2010 3:15:01 PM(UTC)
lmpiazza
Every month my GE Profile Side-by-side ices up on the freezer floor. We break up the ice, clean it up and about a month later the same thing happens. What causes this and how can it be corrected?
applianceman
#2 Posted : Wednesday, June 23, 2010 7:55:54 PM(UTC)
applianceman
The drain is clogged. Look at the back of the freezer and you should see a trough with a hole in the center. That hole is the drain; clean all the ice from around the hole. The best way I have found unclog refrigerator drains is the force hot water down the drain with a turkey baser until water flows freely. Then mix water with baking soda and pour it down the drain to prevent it from clogging again anytime soon.
Refrigerator repair guide
pinoy_ako
#3 Posted : Wednesday, June 23, 2010 7:56:32 PM(UTC)
pinoy_ako
Its normal that function. Not too worry, o
lmpiazza
#4 Posted : Thursday, June 24, 2010 4:33:50 AM(UTC)
lmpiazza
Thanks for the feedback.
lmpiazza
#5 Posted : Thursday, June 24, 2010 4:35:23 AM(UTC)
lmpiazza
Thanks for the reply. Except for the baking soda part, this is what we do every time. I thought there would be something else that could be done to prevent the icing from occuring.
applianceman
#6 Posted : Thursday, June 24, 2010 6:15:09 PM(UTC)
applianceman
Once you clear the drain and pour the baking soda down the drain it shouldn’t ice up again anytime soon. It is not a bad idea to pour baking soda water down the drain once a year. Some people say pour bleach down the drain but I been using baking soda for years and it works great and it don’t smell nearly as bad as bleach.
lmpiazza
#7 Posted : Friday, June 25, 2010 4:44:01 AM(UTC)
lmpiazza
Thank you!
