My dryer recently cooked two wires. One was a jumper wire on top of the heating coil (I think that is what it is) The other went from the coil on top of the gas valve over to a connection on the right back of the dryer. This is a gas dryer Size 30 X 30 Serial # TTKE- 220084-KA I need a wiring diagram and a parts manual and a operation manual or any help that you can give Please, and thanks
There is no any technical information for Huebsch available. You probably have to call a pro.
