damc1962
#1 Posted : 15 years ago
damc1962
I'm sure there is a thermostat for my Amana gas oven, but looking thru the parts diagram, I can't find it. I have a problem with the oven not getting gas, the stovetop works, but the oven doesn't bake or broil. Thought of changing the thermostat and the gas shutoff valve, but can't find the part.
#2 Posted : 15 years ago
Do the Bake and Broil igniters glow when you choose the Bake or Broil on the control panel?
If not, check for 120 VAC to the Bake igniter while the control calls for Bake. Do the same test for the Broil igniter. Post the results.
Here are the breakdown diagrams and Replacement parts for AMANA ACS3350AS Range - S/c S/i Gas | AppliancePartsPros.com
damc1962
#3 Posted : 15 years ago
damc1962
Yes, I tried them both today after work, and they both glow.
Thanks.
#4 Posted : 15 years ago
Check if the gas shut off valve (#26 on the diagram) is open.
damc1962
#5 Posted : 15 years ago
damc1962
Gene, is this an automated valve, that could have shut off on it's own?
I did notice before the oven completely quit, it would take an extra amount of time to reach the correct temperature.
#6 Posted : 15 years ago
This shut off valve is manual as you can see it on the picture.
If the gas valve is open, most likely the problem is a bad igniters.
- The Bake igniter Part number: AP4041245
- The Broil igniter Part number: AP2934763
damc1962
#7 Posted : 15 years ago
damc1962
Gene,
I ordered the part you suggested, the delivery was fast, installation wasn't very complicated, the oven's working fine.
Thanks again for the help.
#8 Posted : 15 years ago
You are welcome. I'm glad you were able to fix it.
rediron
#9 Posted : 14 years ago
rediron
I saw this forum hoping it was my problem, but isn't.... IS there a thermostat 'per se' in the Amana oven model number ARG7302WW or is it all digital? My oven can't even cook a pizza as it won't get hot enough!
