David Obrien
#1 Posted : Tuesday, May 11, 2010 9:08:53 AM(UTC)
David Obrien
I have manually had to defrost twice in the last 30 days. Works fine after defrost. First time the fridge was not cooling, fine after manually defrost. Second time it was conting to run, I check and it was iced up again. Could this be Defrost timer, defrost heater, defrost thersmsatt, or Thermistor ????????????????? Thanks, david
#2 Posted : Wednesday, May 12, 2010 3:24:18 AM(UTC)
Replacement parts for MAYTAG PBF2255HEW Ref - Bottom Mounts | AppliancePartsPros.com
I could not find a tech sheet for this unit. Look under the unit in compressor area for it. Perhaps the following will give the procedure to force a defrost cycle, see Page 38 in the manual.
http://www.servicematters.com/maytag_library/docs/16025629.pdf
Could be any one of the items you mentioned.
Note that you do not have a defrost timer the defrost is controlled from the board.
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Here are a couple good sites with additional info
http://www.applianceaid.com/frig.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
David Obrien
#3 Posted : Tuesday, June 22, 2010 5:26:07 PM(UTC)
David Obrien
THANKS FOR THE REPLY. GREAT INFO. I REPLACED DEFROST THERMOSTAT. (STILL OK) HEATER OK. WAS FINE FOR TWO WEEKS AND FROSTED UP AGAIN. aS YOU SUGESTED I FORCED A DEFROST. THE DISPLY SHOWED F D AND HEATER WORKED. i'M THINKING OF REPLACING ELEC-CONTROL BOARD #AP4366538. "EXCEPT" i READ IN SOME OTHER POSTS THAT IF FORCED DEFROST WORKS ITS NOT A BAD CONTROL BOARD ???????/ kIND OF PRICEY, SHOULD I TRY. THANKS DAVID
#4 Posted : Wednesday, June 23, 2010 4:10:41 AM(UTC)
[COLOR="Blue"]i READ IN SOME OTHER POSTS THAT IF FORCED DEFROST WORKS ITS NOT A BAD CONTROL BOARD[/COLOR]
No, if you can force a defrost is does not eliminate the board, it does eliminate the heater and defrost thermostat. Perhaps the timer section on the board is not working so that the unit never goes into defrost.
[COLOR="Blue"] kIND OF PRICEY, SHOULD I TRY.[/COLOR]
It is all that is left so I would give it a try.
Since you have doe a lot of troubleshooting, if you order it from AppliancePartsPros and it does not fix your problem, they will let you return it.
see their return policy.
David Obrien
#5 Posted : Wednesday, June 23, 2010 11:42:22 AM(UTC)
David Obrien
tHANKS I WILL LET YOU KNOW, YOU GUYS ARE GRAET. DAVID
