After my Maytag dishwasher's handle broke I replaced the entire latch assembly. Now the dishwasher is unable to detect that the door is open and won't pause when I open the door.
There are two small electronic(?) devices that clip onto the assembly and plug into the cables connecting the latch to the controller. I removed these while attempting to figure out how connect the new latch. (I was thinking that I would use the old devices because I was having problems unplugging them from the cables.) I finally succeeded in unplugging the old devices using pliers and a fair amount of brute force but then had difficulty getting the new ones firmly clipped back onto the latch. I reinstalled the latch without the devices firmly clipped onto it. Perhaps this is causing the problem.
Any experts out there who have some thoughts about this?
The model number you posted does not come up. Verify and repost it, please.
