xjoleen2x
#1 Posted : Tuesday, June 22, 2010 11:52:23 AM(UTC)
xjoleen2x
no spark to any of the burners when the gas is turned on. need help finding the right part
#2 Posted : Tuesday, June 22, 2010 2:32:14 PM(UTC)
You may want to start with verifying that there is 120 VAC at the wall outlet.
If there is nothing wrong, replace the spark module. If you need the correct part number, post the serial number of the range.
Here are the breakdown diagrams and Gas controls replacement parts for MAGIC CHEF 31001PAW Range - F/s Std Gas | AppliancePartsPros.com
Viking cooktop no spark to burners on one side other side working properly (Oven Repair (including Ranges and Cooktops))
by drmiked 5/21/2009 7:32:28 AM(UTC)
