DC1
#1 Posted : Monday, June 21, 2010 2:52:43 PM(UTC)
DC1
I am trying to locate a wiring diagram for my frig to aid in troubleshooting a defrost problem, do we have access to them on this site???
#2 Posted : Tuesday, June 22, 2010 3:13:33 AM(UTC)
Replacement parts for tfx30ppdcc models | AppliancePartsPros.com
Pick the one with a close model number, I used ppdBcc.
As far as I know there is no web site that has GE tech info.
They like to keep it a secret, guess it keeps their techs busy.
Luckily you should not need a wiring diagram for a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 257 in Section 5) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 230 in Section 3) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 240 in Section 3) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
GE range replacing a infinite switch but need the wiring diagram (Oven Repair (including Ranges and Cooktops))
by jlsalazar101 1/24/2024 2:49:12 PM(UTC)
Need Old Admiral Wiring Diagram (Washer Repair)
by jkuly 1/15/2024 6:09:44 PM(UTC)
Need wiring diagram for Duet GHW9150PW1 (Washer Repair)
by Conesus 12/14/2022 10:50:49 AM(UTC)
Refrigerator Wiring Diagram (Refrigerator & Freezer Repair)
by Prairie Traveler 11/10/2022 9:39:05 PM(UTC)
Sams RF28K9380SR/AA door connector wiring diagram (Refrigerator & Freezer Repair)
by Guest 9/17/2022 4:09:41 PM(UTC)
Whirlpool LAE550W1 wiring diagram (Dryer Repair)
by z001010racs0 6/29/2022 10:42:02 AM(UTC)
Wiring Diagram for Whirlpool Control Board 2252195 / 2304006 on KSRT25CRM - Help? (Refrigerator & Freezer Repair)
by kpfeif 4/18/2022 10:26:51 AM(UTC)
GE Microwave JVM1540DM4 WW - Looking for wiring diagram (Microwave Repair)
by shotgnz 10/19/2021 12:38:16 PM(UTC)
no wiring diagram for drain pump installation--HELP (Washer Repair)
by TanyaDA 3/17/2021 5:16:46 AM(UTC)
Wiring diagram for W10410892 (Dryer Repair)
by sra2786 4/12/2020 4:55:28 AM(UTC)
Wiring diagram needed Tappan Wall oven (Oven Repair (including Ranges and Cooktops))
by Sandman038 2/2/2020 12:54:48 PM(UTC)
Missing GE Wiring Diagram (Refrigerator & Freezer Repair)
by thumbrfg 8/21/2019 6:05:13 AM(UTC)
missing wiring diagram for WE17x10010 (Dryer Repair)
by ravencc 8/8/2018 2:37:53 PM(UTC)
Reqest wiring diagram for KitchenAid Side-by-Side refrigerator model KSRG25FKSS05 (Refrigerator & Freezer Repair)
by thegreatscott 3/12/2018 5:01:08 PM(UTC)
Where can I find dishwasher wiring diagram? (Dishwasher Repair)
by Nifty 2/18/2018 9:24:52 PM(UTC)
