wdickey
#1 Posted : Sunday, June 1, 2008 7:40:51 PM(UTC)
wdickey
After replacing the pressure switch all the lights on the panel are blinking.
I do not know the model number, but the part # of the switch you sent me is GEH WH12X10173 LOCATION 2C3404? iT IS A 2001 MODEL.
tHANKS
abadfish66
#2 Posted : Sunday, June 1, 2008 9:09:47 PM(UTC)
abadfish66
Really need a model# to help, and please tell me why you replaced the pressure switch...thanks
wdickey
#3 Posted : Thursday, June 5, 2008 5:40:49 AM(UTC)
wdickey
BAD FISH,
THANKS FOR YOUR REPLY. MODEL # ABOVE. i REPLACED THE PRESSURE SWITCH BECAUSE IT WOULD NOT BEGIN A WASH CYCLE. WOULD NOT FILL WATER. WHEN I PUT THE NEW ONE ON, ALL THE LIGHTS ON THE PANEL STARTED FLASHING. I THINK IT NEEDS TO BE RESET OR RE-SYNCHRONIZED. BEFORE I GOT THE NEW SWITCH I TOOK THE OLD ONE OFF AND CONNECTED THE TWO WIRE LEADS AND FILLED THE WASHER UP MANUALLY. THIS WORKED OKAY AND I HOPE IT IS NOT A PRE-CURSER TO THE PROBLEM? THIS IS A GE YEAR 2001 TOP LOAD. OTHER NUMBERS ON THE ENCLOSED WIRING DIAGRAM ARE:175D2750G227-175D2750G227?
123C8294P001 I HOPE THIS HELPS AND I AWAIT YOUR REPLY.
THANKS,
WDICKEY
