ED31
#1 Posted : Sunday, June 1, 2008 6:33:35 PM(UTC)
ED31
My oven stopped baking and broiling after we did a self clean for the first time. I checked for continuity on both the elements and which turned out to be fine. The oven sensor also appears to be OK. There are no error codes on the display. When I set the baking temperature, the fan comes on, the timer comes, the bake light comes and the "Pre" message appears. When the timer counts down to zero, the bake light stays on, the fan stays on and the oven continues to bake, even though it never gets hot. Same with the broiler. This happens regardless of the temperature.
abadfish66
#2 Posted : Sunday, June 1, 2008 9:12:16 PM(UTC)
abadfish66
Check the wall outlet and make sure you have 240volts, then we can go from there
