tinarivera
#1 Posted : Saturday, June 19, 2010 7:05:23 PM(UTC)
tinarivera
Woke Up To A Puddle On The Floor And My Freezer Not Working The Other Side Does Not Seem To Be Getting Cold It Sounds Like Its Running But At A Constant Level And The Ice Maker Is Not Requesting Water.
#2 Posted : Sunday, June 20, 2010 3:19:38 AM(UTC)
Replacement parts for GLHS66EFSB models | AppliancePartsPros.com
The fresh food side gets it's cold air from the freezer so if the freezer goes out so will the fresh food.
First you have to determine is the compressor is running.
You should be able to hear it, it should be vibrating and it should be warm.
Note: The compressor is either on or off it is not variable as far as run speed.
Below are a couple good sites with basic repair and troubleshooting help.
http://www.applianceaid.com/frig.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
