Does any one know how to get the old blade out of this 25,000 BTU window unit?
We took off the case with intentions of replacing the blade.
We were unable to figure out how to replace the blade. The blade it to close to the coil to get out.
Any help will be greatly appreciated!
Originally Posted by: CathyJ  Does any one know how to get the old blade out of this 25,000 BTU window unit?
Any help will be greatly appreciated! u have to move the coil out of way with out kinking the lines
Originally Posted by: CathyJ  Does any one know how to get the old blade out of this 25,000 BTU window unit? We took off the case with intentions of replacing the blade. We were unable to figure out how to replace the blade. The blade it to close to the coil to get out. Any help will be greatly appreciated! You must open the condenser down, and the profeler blade must lose, the the fan motor, then the centrifugal blade. May pilipino ba dito. I-pm nyo ako nang magkakilala tayo. Magtayo tayo ng samahan or grupo. Mag usap tayo sa internet. Or gumawa tayo ng forum na pang pinoy.
