I found the agitator not turning. Dissassymbled the washing machine found the broken coupling! I also found a rubber gasket stuck up in the or near the clutch it's about 7 1/4 inch oval rubbery type gasket. twoo ends are kind of stamped with an impresssion. I can not figure out what this part is.
Can anyone help?
The model number you posted is incomplete or incorrect. Verify and repost it please.
Hi the model number for this washer came off the unit and is exzactly how it is stated in the forum. The unit ids a direct drive and i think it's about 10 years old. I can take a picture of the gasket and send it to you !
Michael
Michael,
A picture posted on the forum might help.
Gene. P.S. This model number is incorrect.
