Mrhaneync
#1 Posted : 15 years ago
Mrhaneync
Kenmore Elite Oasis 110.2703 washer f50 code. I may be making this too hard but I went thru the diagnosis procedure in the repair manual and I need a little clarification. I went into motor RPS test and turning the basket by hand did make the Wash, Rinse and Spin lights toggle on and off. So question 1: Doesn't this verify that the RPS switch is doing what it's supposed to do and therefore is not bad? I followed thru the Manual:Motor Test #3 until step #6 tested ok and I was instructed to go to step #11 which states that the drive motor and lower harness are both good. It now tells me to replace the RPS board and perform the Diagnostics test in step #1 to verify the repair. So here's my 2nd question: Where is this RPS board located on the machine? I have been unable to find it shown anywhere in the manual. Maybe I'm confusing it with the Machine/Motor control, but I don't think so as that board is the one shown in step #12 as the next fix to try if step #11 didn't work. Any help would be greatly appreciated and make my life easier(my wife wants her washer fixed) Thanks, Mark
Mrhaneync
#2 Posted : 15 years ago
Mrhaneync
Kenmore Elite Oasis washer 110.27032603. Changed both the RPS and the Machine/Motor board. Of course it was the 2nd, more expensive one that was bad.
