hess99
#1 Posted : Tuesday, June 15, 2010 7:14:23 PM(UTC)
hess99
The frig is a GE Profile side by side model PSS26PSTA. The freezer side is working fine the frig side was up to 60F when set for 37F. I traced the problem to the fan in front of the evaporator coils not running. I tested the 12V fan and it was dead. I went to an electronics store and bought a new 12V fan and installed it it didn't work, so I tested it on the bench and it worked fine. The test meter showed 12V at the connection in side the frig so I put an Amp meter in line, the old fan was rated for 0.42A and the new is 0.37A, the Amp meter reads 2ma. So why am I not getting enough current? Please post any ideas.
#2 Posted : Wednesday, June 16, 2010 12:56:23 AM(UTC)
Your amprobe will not measure dc current. There is supposed to be a square wave from the motherboard, that current you could measure. Replace the motherboard AP3957581
hess99
#3 Posted : Wednesday, June 16, 2010 3:57:41 AM(UTC)
hess99
The amp meter I used was in series with the fan, not a just a amp probe
#4 Posted : Wednesday, June 16, 2010 6:00:18 AM(UTC)
You must use the fan that GE used, a regular dc fan motor will not work.
hess99
#5 Posted : Wednesday, June 16, 2010 6:12:11 AM(UTC)
hess99
Why it was a 12v muffin fan and I replaced it with a 12v muffin fan. The motherboard can't tell the difference.
#6 Posted : Wednesday, June 16, 2010 7:33:58 AM(UTC)
It must be a AP4438809, a special fan motor
hess99
#7 Posted : Wednesday, June 16, 2010 8:09:16 AM(UTC)
hess99
12v two wires 0.42A nothing special
#8 Posted : Wednesday, June 16, 2010 8:40:23 AM(UTC)
If you want it fixed, replace the evaporator fan motor and the motherboard!!
#9 Posted : Wednesday, June 16, 2010 3:46:00 PM(UTC)
The motherboard puts out a 12 v square wave, variable frequency, and also a dc voltage. If you tap onto the 12vdc line, you are probably overloading the motherboard and burning out some driver.
By putting in a non-standard fan motor, you may get performance for a period, but you risk failure later. If I knew the electronics involved, I could give you a more definitive answer.
Also, the variable frequency drives the evaporator fan motor faster at different periods when faster cooling is necessary. A constant velocity motor will probably confuse the motherboard computer and result in cycling interruptions of cooling in some way unknown to me.
I know you are trying to save money here, but this refrigerator will defeat you every time.
The only safe way to drive a dc fan motor is to tap into a 12 volt power source on the motherboard and hope GE has enough current margin in the supply to prevent burnout. However, you would need to stop the fan during defrost.
Guest (4)
