jacque
#1 Posted : Friday, May 30, 2008 6:22:34 AM(UTC)
jacque
oven is a single wall unit. will be replacing in 3 years with kitchen remodel. all oven features work IE: heats, self clean, correct temp.
(Timer features i don't use, does not work.) oven came with house.
after my hubby was burning cookies. i noticed the fan in the top (above oven, near all the controls) is not working. Is there a fuse i can check. inside the panal or do i need to replace the fan motor.
thanks for any help.
abadfish66
#2 Posted : Friday, May 30, 2008 7:32:09 AM(UTC)
abadfish66
Is this the old P7 oven with the mechanical clock on the left side, if it is, the fan motor is located in the back of the oven, meaning to get to it you need to remove the oven, also how comfortable are you when it comes to working around live 240volts to diagnose. If neither of those are an option, I would recommend a service call...
