Jfriedm
#1 Posted : Tuesday, June 15, 2010 5:37:38 AM(UTC)
Jfriedm
My washer is 3 yrs old and gets very little use 2-3 times a week for 6 mos. The problem is it fills with water and then does started when it aggitated and then did not drain or spin... Now it only fills with water... I hear the timer click and nothing... I have already replaced the lid switch and same thing happens... Before I buy and install any more parts, Does anyone know what it is?
sidfink43
#2 Posted : Wednesday, June 16, 2010 5:12:22 PM(UTC)
sidfink43
Since you know how to take off the cabinet, do it and then take off the pump and motor and check the motor coupling.
