Mike Hutchinson
#1 Posted : Monday, June 14, 2010 1:48:47 PM(UTC)
Mike Hutchinson
the buzzer on the bottom of my freezer stays on, I believe it is called a brk alarm I would like to know what it is for
#2 Posted : Tuesday, June 15, 2010 3:26:51 AM(UTC)
Replacement parts for FRIGIDAIRE LFFH1467DW3 Frigidaire/freezer | AppliancePartsPros.com
Here is the manual for it
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/297080400en.pdf
And a tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/297010000.pdf
I think it is a temperature alarm.
Check the temperature in the unit, should be around 0 degrees F.
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Frigidaire Freezer Handle (Refrigerator & Freezer Repair)
by Guest 1/21/2024 12:46:23 PM(UTC)
Frigidaire freezer model mfu14m2gw0 (Refrigerator & Freezer Repair)
by HEAT8028 11/9/2022 6:58:32 PM(UTC)
Frigidaire Freezer - Does this dryer need to be replaced? (Refrigerator & Freezer Repair)
by jlchafin256 8/26/2022 8:17:22 AM(UTC)
Low side pressure reading - Frigidaire freezer (Refrigerator & Freezer Repair)
by jlchafin256 8/25/2022 4:37:58 AM(UTC)
Frigidaire freezer model number (Refrigerator & Freezer Repair)
by Elmer2020 7/18/2022 7:39:47 AM(UTC)
Frigidaire Freezer Door Pops When Opening - FFHB2750TS / Effortless Glide / Under French Doors (Refrigerator & Freezer Repair)
by daved31415 1/23/2021 12:44:44 PM(UTC)
Frigidaire freezer side not freezing, fridge side not very cold (Refrigerator & Freezer Repair)
by tenlbham 4/13/2019 1:48:16 PM(UTC)
Frigidaire Freezer error alarm (Refrigerator & Freezer Repair)
by mlkk993 10/26/2018 1:31:09 PM(UTC)
Frigidaire Freezer Only Top Coil Frozen (Refrigerator & Freezer Repair)
by mcmillbs 1/27/2018 8:45:38 AM(UTC)
Frigidaire Freezer warms then cools (Refrigerator & Freezer Repair)
by fridgeissues 10/5/2017 6:15:19 AM(UTC)
Frigidaire freezer HI TEMP (Refrigerator & Freezer Repair)
by Jellowe 5/24/2017 4:05:05 AM(UTC)
Frigidaire Freezer Compressor Hot (Refrigerator & Freezer Repair)
by swglenn 10/25/2015 5:32:56 AM(UTC)
Frigidaire Freezer (Refrigerator & Freezer Repair)
by bkw 9/29/2015 5:28:25 AM(UTC)
How do you remove a Frigidaire Freezer contol board (Refrigerator & Freezer Repair)
by TxSmallFry 8/6/2015 4:49:11 PM(UTC)
