My GE side by side started making noises, I assume it is the evap fan as it only happens when the fridge is running a certain cycle.
It seems to be keeping temperature pretty well so frar (8 deg on freezer and 37 on fridge).
Should I replace just the evap fan motor? Or should I replace the motor grommets, fan blade, etc? What all parts should I replace?
If I replace just the fan, do I have to replace the main board as well? (Hopefully not).
