Hi there,
My air conditioning is always on, even after I turned control switch for the blower or turn off the thermostate. The only way to turn it off is to cut the electricity from circuit breaker.
Any idea?
Thanks, Ning
I have Comfortmaker RPJ II (heating and cooling). Thanks.
Originally Posted by: leafhppr ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have Comfortmaker RPJ II (heating and cooling). Thanks. Check wiring. Also furnish Model number
Thanks for your reply. Please advise which wiring I need to check. The machine worked fine just a few days ago and blower and controller seem all working (automatically turned on/off), except air conditioning never stops. Very strange.
Originally Posted by: leafhppr ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks for your reply. Please advise which wiring I need to check. The machine worked fine just a few days ago and blower and controller seem all working (automatically turned on/off), except air conditioning never stops. Very strange. My unit is doing the same. runs, all the time gotta shut it off by switching off power, lol:mad:
Disconnect the yellow wire on thermostat and see if A/C stops.
Originally Posted by: northshore ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) :eek: O/P Stated that that the blower (fan) stops,therefore the fan relay is not sticking. Sounds like the compressor contactor is sticking. Removing the yellow (to compressor contactor coil ) will prove this.
