To Change Lid Switch Which I Can Buy From You The Manual Says To Remove 2 Screw On Front Of Control Cabinet And Tilt Backwards
But The Unit Does Not Have Any Screws To Remove I Know What They Are Talking About Because I Saw Screws On Another Washer Butnot On This Model Any Where To Find Out How To Unplug The Lid Switch Or Tilt Control Panel Back
On your model it appears the screws are on the back. Take them out and the control panel will flip up and back. You can now disconnect the lid switch, pop out the clips holding the cabinet to the back with a screw driver and the cabinet will come forward and come off.
This will give you access to the lid switch.
